SriniK's avatar
SriniK
WNDR4700 Readyshare not working when used just as a router
Hi, I recently changed my ISP (Eastlink in Canada) who provides Eero mesh networking devices.  They have provided Eero Pro 6E.  It has 2 ethernet ports.  One is connected to the modem so the Eero wor...
  • michaelkenward's avatar
    michaelkenward
    Jan 28, 2025
    SriniK wrote:
    The laptop is connected to the ethernet port on WNDR4700, not to Eero.
    The wifi on WNDR4700 is turned off.
    I'll check and work on putting the WNDR4700 in AP mode and see how it goes.
    That should work.
    You have everything else set up as expected.
    Just another user with time on their hands.
