SriniK
Jan 27, 2025Aspirant
WNDR4700 Readyshare not working when used just as a router
Hi, I recently changed my ISP (Eastlink in Canada) who provides Eero mesh networking devices. They have provided Eero Pro 6E. It has 2 ethernet ports. One is connected to the modem so the Eero wor...
- Jan 28, 2025
SriniK wrote:
The laptop is connected to the ethernet port on WNDR4700, not to Eero.
The wifi on WNDR4700 is turned off.
I'll check and work on putting the WNDR4700 in AP mode and see how it goes.
That should work.
You have everything else set up as expected.
Just another user with time on their hands.
SriniK
Jan 28, 2025Aspirant
Thankyou michaelkenward for taking time in reading through my situation and giving suggestions.
Yes there is a Hitron modem which is just a modem. One port of Eero is plugged into Hitron modem. second port of Eero is plugged into WNDR4700 ethernet port. The laptop is connected to the ethernet port on WNDR4700, not to Eero.
michaelkenward
Jan 28, 2025Guru - Experienced User
That should work.
- SriniKFeb 18, 2025Aspirant
michaelkenward the solution to put the router into AP mode worked. Now I am able to connect the router to my new network and all devices are able to see the Readyshare NAS. I also found that any external USB drives connected to the Centria USB ports are also visible on the network. This is working more than expected.
Apologies for the late reply as I was out of town. Thanks.
- michaelkenwardFeb 19, 2025Guru - Experienced User
That's good. It is nice to have a way to keep access to those USB devices. I still have an old R7800 router in the network just fir that purpose.
Disclaimer: Just another user with time on their hands.
