Bubbaphillips
May 28, 2024Aspirant
WNR 2000
I have forgotten my password and having no luck guessing it. Ipad is using the router as well as IPhone and desktop. Trying to add a security camera but can’t without the password……HELP
michaelkenward
May 29, 2024Guru - Experienced User
Password for what? Wifi from the WNR2000?
Check what microchip8 suggests.
By the way, that's an ancient router. Originally from 2005, the most recent (V5) version seems to be from 2014.
It may not be happy if you try to add too many IoT devices to the limited wifi capacity.
No 5 GHz wifi, wired LAN stuck on 100 MBps. If your Internet speed is anything faster than that, you are wasting money.
