AZGold's avatar
AZGold
WNR 2000v5 - Not connecting
I bought a new modem. The router powers up, has wifi but will not connect to the internet.
Tried new either net cable.
The unit doesn't seem to have a factory reset button.
Any help would be appreciated.
  • michaelkenward's avatar
    michaelkenward
    Which unit? The reset button on the WNR2000v5 is cunningly hidden on the bottom.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Find the section Factory Settings.
    Just another user with time on their hands.
  • plemans's avatar
    ah jeez. I can't believe they're still selling that old N300 device.
    It wasn't fast when it was released in 2009. And is only a 10/100mbps device.
    Unless you're on some pretty slow service, its time to retire that router and get something from at least last generations of devices.
      michaelkenward
      I bet they aren't on sale. Just someone found something lying in the bottom of a cupboard and decided to dig it out.
      It really does belong in the e-waste recycling bin. More useful there. But that wasn't the question.
      There are too many unanswered questions to suggest much else.
      That hidden reset button was a weird aberration on the part of whoever designed those things. I had something similar way back when.
    • AZGold's avatar
      AZGold
      Thank you to everyone for your replies.
      I looked back in my download folder and found the Net Genie program from a long time ago.
      I installed that and went through a few set up items and the router is now working.
      I use it to stream prime, netflix, and the internet connection on my fire TV.
      It never has let me down while working. No buffering...
      I am returning the new router I bought to Amazon....
      reuse, recycle, replace as a last resort.
