Hypnos
Jul 03, 2016Aspirant
WNR 2200 No Connection to modem
Hello! Forst things first, I am from Germany and my provider is Kabel Deutschland. Sorry if some terms are incorrect :-) We have the WNR2200 for acouple of years now and everything was fine. Las...
- Jul 03, 2016
Did the Internet light on the router turn green after you cloned the MAC address of your computer onto the router?
Can you access the Internet through your router's LAN port? If so, then your WLAN is probably not set up.
Hypnos
Updating firmware also brought no solution.
