Hypnos
Jul 03, 2016Aspirant
WNR 2200 No Connection to modem
Hello! Forst things first, I am from Germany and my provider is Kabel Deutschland. Sorry if some terms are incorrect :-) We have the WNR2200 for acouple of years now and everything was fine. Las...
- Jul 03, 2016
Did the Internet light on the router turn green after you cloned the MAC address of your computer onto the router?
Can you access the Internet through your router's LAN port? If so, then your WLAN is probably not set up.
TheEther
Jul 03, 2016Guru
Hypnos
I... kind of... followed your advice.
I connected the PC with the router, but still no connection to the internet.
So I copied the PCs MAC-address again, set the genie to "use the computer's MAC-address" and then some magic happened and now everything works fine again.
I'm a liitle bit confused but very very happy right now :-)
