dustybin
Dec 18, 2015Aspirant
WNR 2200 should I update from V1.0.1.68_RANDOMNTPPORT?
I previously had problems using an NTP server behind this router and Netgear kindly provided me with the subject modified firmware. Can you tell me if the modofication was incorporated into the late...
- Dec 21, 2015
OK - thanks. I'll try that when I get a chance, although it could be a while as I think the file may be on my old machine.
All the best - thanks again.
Retired_Member
Dec 19, 2015Nothing in the release notes I found mention it. This is not uncommon, they don't list everything. Try it as long as you have a copy of the one they sent you should be able to revert back to it.
- dustybinDec 21, 2015Aspirant
