Chrisses
Dec 22, 2021Follower
Wnr 3500lv1need the recovery software after failed dd-wrt build am unable to log in
Dec 22, 2021Guru - Experienced User
If you had ddwrt on it, you should check with their forum on how to remove their firmware. They'd be the experts on removing it.
Our advice could make it worse.
