Ericomccabe
Oct 06, 2015Aspirant
WNR1000 v3 N150 Wireless Router not working for Windows 10
I recently upgraded my computer to Windows 10 and it no longer connects to my WNR100 v3 wireless router. The computer connects to other wireless networks without issue and the wired connection with t...
- Oct 11, 2015
Good News, Everyone!
The issue is resolved. I did a hard reset of the router, the modem, and the computer. I'm not sure exactly which one made the difference, but in any event, the wireless works now. Thank you for all of your troubleshooting suggestions, I really appreciated the help
Ericomccabe
Oct 10, 2015Aspirant
TheEther - Good thought. I just went in and saw that it was already disabled. I enabled it just to check if that would do anything but it did not. Even after adding my MAC address as a permitted address, it was not able to connect. I disabled it again before leaving the tool
Ericomccabe
Oct 11, 2015Aspirant
- Babylon5Oct 11, 2015NETGEAR Employee Retired
Well it’s great that it’s fixed, and while I’m intrigued as to what the issue was, hopefully it will not return.
