marcobarzaghi
May 06, 2018Aspirant
WNR1000 V3 Reset Trouble
Hi,
I've a netgear wnr 1000 v3 since 6yrs.Yesterday having access to the control panel for some checks I've noticed a notification about a firmware update due security patch. I acepted to upgra...
- May 06, 2018Instead to run recovery utility from Windows 10 I used a Windows 7, now I solved. Hope it helps in case someone else is having the same problem. Marco
marcobarzaghi
Here the screenshot of "NETGEAR Router Firmware Recovery" while I try to make standard recovery workflow.
Marco
marcobarzaghi
Marco
