joesouza
Jul 20, 2023Aspirant
wnr1000v4 latest firmware disparity
Hi, When I visit the wnr1000v4 support page the latest reported firmware is 1.1.0.54. https://www.netgear.com/support/product/wnr1000v4#download However there is a later security advisory artic...
- Jul 20, 2023
FURRYe38 wrote:
One can find newer used or referb'd routers online for fairly inexpensive. Got a few off Amazon.
Good thinking. Fix your budget and look around.
Start with deciding what you want to do with this router, and then find something that fills the bill and fits your budget.
If you want to stick with Netgear, try plugging your needs into the filters on the product pages:
WiFi Routers | Wireless Routers | NETGEAR
and
NETGEAR'S Mesh WiFi Network Routers + Systems
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
Jul 20, 2023Guru - Experienced User
michaelkenward
and
