Zipper666
Nov 29, 2020Initiate
WNR2000.
My elderly neighbor has a Netgear N300 - WNR2000 and the power supply has failed. It's and MT20-21120-A00F manufactured by Leader Electronics. Online they seem to be available from various sources ...
Nov 29, 2020Guru - Experienced User
No. Netgear doesn't sell power supplies.
But luckily, you can get a 3rd party adapter. Just make sure it has the same voltage and AT LEAST the same amperage. You can have more but I wouldn't recommend less.
I've done this several times and its worked great.
- Zipper666Nov 29, 2020Initiate
Thanks, I had come to that conclusion.
Sadly, the chat function wasn't helpful, they could simply have checked and told me that instead of
carrying on about warranty and wasting my time.
- plemansNov 29, 2020Guru - Experienced User
They probably could have. But sadly, netgear outsourced their support to gearhead. its made getting help challenging unless you pay for it. Which is why there's the forums.
- wcalifasNov 29, 2020Prodigy
You can get those power supplies cheap on amazon or ebay, whatever you prefer.
