Zipper666
Nov 29, 2020Initiate
WNR2000.
My elderly neighbor has a Netgear N300 - WNR2000 and the power supply has failed. It's and MT20-21120-A00F manufactured by Leader Electronics. Online they seem to be available from various sources ...
Zipper666
Thanks, I had come to that conclusion.
Sadly, the chat function wasn't helpful, they could simply have checked and told me that instead of
carrying on about warranty and wasting my time.
Nov 29, 2020Guru - Experienced User
They probably could have. But sadly, netgear outsourced their support to gearhead. its made getting help challenging unless you pay for it. Which is why there's the forums.
- wcalifasNov 29, 2020Prodigy
You can get those power supplies cheap on amazon or ebay, whatever you prefer.
- michaelkenwardNov 30, 2020Guru - Experienced User
A few details missing from the earlier answers, any generic adapter will work, as long as it has the right volts, enough amps and a tip with the right (+/-) polarity and dimensions.
