LindaCurtis
Jun 18, 2021Aspirant
WNR2000-100NAS
My Netgear router is working fine. I was scammed on 6/7/21. My computer was shut down - they offered to help - gave them my ID# and password. They wanted a lot of money - shut them off. Question - Ma...
antinode
Jun 18, 2021Guru
> My Netgear router is working fine. [...]
Ok. "WNR2000-100NAS" is the extended name for a WNR2000[v1]. Look
for "Model" on the product label.
> [...] Question [...]
I see no question.
> [...] Macafee is blocking your I.P.192.168.1.1 because they feel it
> may be corrupted. Coming in at the wrong port. They know your normal
> port. [...]
I don't know what that means, or where you got any of it.
> [...] I would like to update my firmware - everytime I try to sign in
> it says bad request. [...]
To me, that doesn't sound like "working fine". What, exactly, are
you doing? What's the actual error message?
> [...] Anyway I can update?
It'd be difficult if you can't get logged into the router's
management web site using a web browser.
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual (at least). Read.
Look for "Troubleshoot" and "Reset". Further reading might not hurt,
either.
