Coach_Olsson
Aug 12, 2015Tutor
WNR2000 doesn't broadcast SSID, can't find it on list of wireless networks
Hello, I recently moved and after I got my internet up and running, I plugged in my WNR2000 router so I could wirelessly connect to the internet. After I set up the wireless in the browser, and t...
- Aug 14, 2015
Coach_Olsson, I’m pretty sure that your router has corrupted flash memory and you will not be able to change the firmware or turn on WiFi, I have sent you a PM with details on how to seek an RMA.
Coach_Olsson
Aug 13, 2015Tutor
Did it, didn't work.
ElaineM
Aug 13, 2015NETGEAR Employee Retired
Hi Coach_Olsson,
Do you happen to have traffic meter enabled on the router? This is under "Advanced" tab. Kindly, uncheck if it's selected and let us know the result. However, if it's not selected, did you try upgrading the firmware?
- Coach_OlssonAug 13, 2015Tutor
Traffic meter is not enabled. Tried to upgrade firmware but...
- Babylon5Aug 13, 2015NETGEAR Employee Retired
Were you trying to upload firmware from a file previously downloaded to your PC, or were you using the router’s check for new firmware function?
Using the router's check for new firmware.
