Coach_Olsson
Aug 12, 2015Tutor
WNR2000 doesn't broadcast SSID, can't find it on list of wireless networks
Hello, I recently moved and after I got my internet up and running, I plugged in my WNR2000 router so I could wirelessly connect to the internet. After I set up the wireless in the browser, and t...
- Aug 14, 2015
Coach_Olsson, I’m pretty sure that your router has corrupted flash memory and you will not be able to change the firmware or turn on WiFi, I have sent you a PM with details on how to seek an RMA.
netwrks
Aug 14, 2015Master
I would try reflashing to factory, then downgrade to another version of firmware, if the router still won't let you change any settings..
Babylon5
Aug 14, 2015NETGEAR Employee Retired
- troya13Nov 26, 2015Aspirant
I am having the same problem. I have also tried all the steps in the fix tool and that didn't work either.
Please advise.
- troya13Dec 04, 2015Aspirant
Thank you for the reply. My router has both issues- can't update firmware and doesn't broadcast SSID. I tried the "WNR2000v4 fix tool- Unable to see WNR2000v4 wireless network nor update router’s firmware. " http://kb.netgear.com/app/answers/detail/a_id/27207
- ElaineMDec 07, 2015NETGEAR Employee Retired
@troya Kindly check your inbox.
