rg1911
Mar 26, 2022Aspirant
WNR2000 V4 modem router displays "Please wait a moment" continuously at login
Router Firmware Version V1.0.0.50 Web browser: Firefox 98.0.2 (64-bit) When I try to log in to the router, the screen always displays "Please wait a moment." This never changes. Today, tryin...
- Mar 27, 2022
I don't know what browser you tried upgrading your router with, but I suggest you using Microsoft Edge in attempting to apply that firmware upgrade. I think there's bugs with other browsers when trying to upgrade from a browser.
michaelkenward
Mar 27, 2022Guru - Experienced User
Might be useful.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
rg1911
Mar 27, 2022Aspirant
I should have mentioned that I had checked the Netgear support options and had tried the methods that were suggested. I am able to navigate to Advanced/Administration/Firmware Upgrade; but when I click "Check," the "Please wait..." message displays and never changes.
I had also downloaded the upgrade file and tried the Upload method. As before, the "Please wait..." message displays and never changes, no matter how long I wait.
Thank you,
Richard
- michaelkenwardMar 27, 2022Guru - Experienced User
Your subject says " WNR2000 V4 modem router". It isn't a modem.router. Just a router.
So what modem/gateway sits between the router and the Internet?
Is the WNR2000V4 in router or AP mode?
You do realise that the "new" firmware for this device is five years old?
According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware. This may not matter to you, but be warned that it will hobble you if you ever sign up for faster Internet. It also slows down whatever is going on in your local network. Newer devices support 1000BASE-TX.
Nothing wrong with it being old, just don't expect too much.- wcalifasMar 27, 2022Prodigy
- rg1911Mar 27, 2022Aspirant
D--n! Using MS Edge did it. I've been using Firefox.
Thank you; I had not seen any other information that said some browsers were buggy with respect to the router.
Cheers,
Richard
That is my mistake. I copied the title from an older post by someone who had a different router but the same problem.
A dish with line-of-sight to the tower. Or is that not what you're asking?
Good question, to which I don't know the answer. It's been chugging away for so long that I've forgotten how I originally configured it, and it's gone through a couple moves. I will make the guess that it's in Router mode.
Yup.
> "According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware. This may not matter to you, but be warned that it will hobble you if you ever sign up for faster Internet. It also slows down whatever is going on in your local network. Newer devices support 1000BASE-TX.
Nothing wrong with it being old, just don't expect too much."
I had not considered that at all, and I am paying for faster service. The current router, by the way, is directly cabled to the dish.
I think the fix is a modern router. Are there any recommendations?
Thank you,
Richard
