nkravit
Jun 02, 2018Aspirant
WNR2000v-3 Router
I just rebooted my router and lost my connection to a Roku device. My cell phone won't connect any longer either. So I think the whole Wifi network is off. I set it up long ago enough that I don't...
- Jun 03, 2018
I tried again after several hours and surprise! It connected. Earlier, I was getting messages from my devices that no internet connection was detected. I have no idea what changed, but it didn't appear to be anything I did. So I've now connected the internet with my streaming device and with my cell phone. I'm very relieved. Thanks to michaelkenward for trying to help.
michaelkenward
Jun 03, 2018Guru - Experienced User
Are the wifi LEDs lit on the device?
Do you have wired devices that can connect? Or is the whole Internet down?
- nkravitJun 03, 2018Aspirant
- nkravitJun 10, 2018Aspirant
Yes I did have wired devices that could connect. But it turned out that the solution was very simple. I waited (partly out of frustration I turned to doing something else) and after an hour or so the system had found my wireless signal and I was able to complete the set-up. Thank you so much for responding!
