JimVM
Dec 12, 2016Aspirant
WNR2000v2 - WiFi Password
I have had router about 6 years with no problems. I set it up with WEP security and it is connected to my desk top and cable modem. I have Kaspersky Internet Security and when I start up my lap top i...
- Dec 19, 2016
JimVM Kindly see the link below on how to change the WiFi password.
Anonymous
Dec 12, 2016You cannot go from WEP to WPA2 with changing PW.....use a wired PC login to router verify WPA2 security settings.
JimVM
I have verified the WPA2-PSK setting on my desk top through "Net Gear Smart Wizerd Router Manager." Are you saying that once that is changed that the password is no longer valid and I should change it?
- JimVMDec 12, 2016Aspirant
I went ahead and changed the password under my log in account under Maintenance, Set Password. The old password came with the router and was 26 digits. I assigned the new password (18 digits) entered twice as instructed and clicked apply. When I tried to set up the wifi with an iphone I got an enter password I entered the new password and it came back as incorrect. I admit I am not a "techie." Did I change the password correctly or are there other steps that I should take.
