JimVM
Dec 12, 2016Aspirant
WNR2000v2 - WiFi Password
I have had router about 6 years with no problems. I set it up with WEP security and it is connected to my desk top and cable modem. I have Kaspersky Internet Security and when I start up my lap top i...
- Dec 19, 2016
JimVM Kindly see the link below on how to change the WiFi password.
JimVM
I have verified the WPA2-PSK setting on my desk top through "Net Gear Smart Wizerd Router Manager." Are you saying that once that is changed that the password is no longer valid and I should change it?
JimVM
I went ahead and changed the password under my log in account under Maintenance, Set Password. The old password came with the router and was 26 digits. I assigned the new password (18 digits) entered twice as instructed and clicked apply. When I tried to set up the wifi with an iphone I got an enter password I entered the new password and it came back as incorrect. I admit I am not a "techie." Did I change the password correctly or are there other steps that I should take.
- AnonymousDec 12, 2016
You appear to be setting wrong password, Wifi password or PassPhrase is changed in the WIFI setup... suggest you read the manual we all did at one time or another.
- ElaineMDec 19, 2016NETGEAR Employee Retired
- kreillynaumJul 26, 2017Aspirant
I have never added a wifi password. How do I add one?
The router password I never changed
