Starbuckz8
Dec 29, 2018Initiate
WNR2000v2 port forwarding only forwards UDP
I've had a WNR2000v2 working for some time. I recently decided to do a firmware upgrade and went from firmware version 1.0.0.40_32.0.54 to the current version 1.2.0.8_36.0.60.
During the firmw...
- Jan 03, 2019
> rolled back to version WNR2000v2_V1.2.0.6_36.0.58NA and everything
> just magically worked. [...]
Thanks for the report. Welcome to the wonderful world of Netgear
firmware quality control. (It's under such tight control that hardly
any of it escapes?)
antinode
Dec 29, 2018Guru
> [...] However if I then select the very same custom service and edit
> it, it only displays "UDP". [...]
Either the report is wrong, or the underlying setting is wrong.
> [...] TCP only things, such as port 3389 (RDP) do not resolve
> externally.
Sounds as if the underlying setting is wrong. I can't see your
actual port-forwarding rule. Did you do everything else right?
External and internal ports? Target IP (static or reserved dynamic)?
If all should be well, then I'd try some older firmware version(s), and
see if I could find one which works.
Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions.
Starbuckz8
Jan 03, 2019Initiate
Thanks for the reply, and sorry for the delay as I wanted to actually try your suggestion. But with holidays and traveling, pushed it off until I was home and I didn't want to answer "Did you do everything else right?" the way the average internet person would. But they were entered correctly, just wasn't accepting the change.
One odd thing I noticed later, is it could be set to TCP or UDP, just not TCP/UDP. Which would have been a temporary viable work around.
Thanks for suggesting rolling back the firmware. The hardware I work on actually can not go backwards, so I completely forgot about this as an option.
I rolled back to version WNR2000v2_V1.2.0.6_36.0.58NA and everything just magically worked. I could edit the old rules to be TCP/UDP, save and they properly got forwarded. And fortunately all the settings were preserved.
- antinodeJan 03, 2019Guru
any of it escapes?)
