arvlar
Jan 03, 2017Aspirant
WNR2000v2 router as a repeater unit
Hi I have a Nighthawk X6 R8000 and would like to connect a WNR2000v2 as a repeater unit to improve the wireless coverage. How can I do that? I've tried according to the manual but it won't work. ...
- Jan 03, 2017
Welcome to the community, arvlar
The R8000 does not support Wireless Repeating.
In order to successfully do Wireless Repeating, both routers should support WDS feature.
At this point, WDS is not present on the R8000.You may run a long cable between the two of them to extend the wireless signal.
ElaineM
Jan 03, 2017NETGEAR Employee Retired
