GBallantyne
Oct 07, 2021Aspirant
WNR2000v2 router connected to Viasat router - what LAN IP address should my Netgear router use?
Sorry if this is a network newbie sort of question.... I've got internet access thru Viasat, and my LAN router (Netgear WNR2000v2) is connected to it. The Viasat router is IP address 192.168.1.1 whic...
- Oct 09, 2021
All fixed up. There were two issues, double NAT configuration and a public IP address on the Netgear router. Bridge mode now enabled on the Viasat router, and Netgear router given private IP address and address pool.
Oct 07, 2021Guru - Experienced User
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
- GBallantyneOct 07, 2021Aspirant
Thanks - this gives me a few things to look at. I also see by reading your response I have a little more learning to do to understand it.... but learning is a good thing.
- GBallantyneOct 09, 2021Aspirant
