rbhall52
Jun 21, 2017Follower
WNR2000v3 firmware upgrade
I just got an email today about a firmware upgrade for my WNR2000v3 router. I followed the instructions in the email, and also logged into my router to check the firmware version number. The router's...
ElaineM
Jun 25, 2017NETGEAR Employee Retired
SupeDogg What's the exact version of your router? You can always update the firmware manually or using the auto firmware update on the router. I suggest that you verify the exact model number of your router and download the manual here.
kperry5465 I suggest that you verify the IP address of your router by following the steps from the link below.
SupeDogg
Jun 25, 2017Aspirant
Thank you for responding, Elaine. Netgear N300 WiFi Cable Modem Router. Model C3000. I do not see anywhere on the router itself to upgrade...only an on/off button on the back. I downloaded the manual, but do not see anything regarding "maintenance."
Thank you,
Jeff
- Angel94Jun 25, 2017Aspirant
HI Supe Dog
Usually firmware upgrades for C devices are done by the cable providers
If you call your internet service provider they will be able to upgrade the firmware for you
