BishopGT's avatar
BishopGT
Initiate
Jul 23, 2017
WNR2000v3 Wireless broadcasting but little to no internet connection
Good afternoon!  I'm hoping someone has run into this before and maybe I just didn't search for the right keywords, etc.
I have a WNR2000v3 router that has been working fine for years, but yesterday something went wrong.  It is still broadcasting and other devices can connect with no issue, but there is little to no internet access on the wireless connection.  Sometimes things will partially load slowly but not finish, e.g. news apps on phone, Netflix on TV will load menus but not actually play anything, HBO/Youtube on TV won't go past title screen.
I'm running V1.1.2.6 Firmware, and the WIRED connections are working just fine.  It is just the wireless that is suddenly having issues.
I'm not a networking pro, but I'm far from a novice.  I've tried rebooting, unplugging, power cycling, messing with Genie settings, but nothing seems to work.
Any help would be much appreciated - thanks!!
Adam
  • Thanks for suggestion!
    Led me to notice that Genie wasn't showing correct info like firmware, updates, etc. Logged directly into router, updated Genie, manually updated firmware and changed channel for good measure (actually had 5 things on same channel, just 1 on another).
    Seems to be back up and running after another round of restarts.
    Thanks!
  • Have you tried changing the Wi-Fi channel?  A neighbor could have set up a Wi-Fi network recently, or some other device, like a baby monitor, microwave oven, cordless telephone, etc., could be transmitting on the same frequency.
    • BishopGT's avatar
      BishopGT
      Initiate
      Thanks!
