Zilimidori
Aug 14, 2017Aspirant
WNR2000v4 cannot enable wireless radio
Hello I have just moved and am trying to set up my old router in a new apartment. After much gnashing of teeth, I finally got the wired connection working, but I cannot seem to enable the wirelss ...
- Aug 15, 2017
Have you tried following the article below?
https://kb.netgear.com/27207/Unable-to-see-WNR2000v4-wireless-network-nor-update-router-s-firmware
Zilimidori
Oops. I don't think I made it very clear about the firmware upgrade bit. I tried (and I think succeeded) in updating it manually by plugging my computer directly into the modem and downloading it from the netgear site and then using the tftp2 program.
- michaelkenwardAug 14, 2017Guru - Experienced User
Did the upgrade take?
What do the lights look like?
The manual is here:
