Zilimidori
Aug 14, 2017Aspirant
WNR2000v4 cannot enable wireless radio
Hello I have just moved and am trying to set up my old router in a new apartment. After much gnashing of teeth, I finally got the wired connection working, but I cannot seem to enable the wirelss ...
- Aug 15, 2017
Have you tried following the article below?
https://kb.netgear.com/27207/Unable-to-see-WNR2000v4-wireless-network-nor-update-router-s-firmware
Zilimidori
Oops. I don't think I made it very clear about the firmware upgrade bit. I tried (and I think succeeded) in updating it manually by plugging my computer directly into the modem and downloading it from the netgear site and then using the tftp2 program.
michaelkenward
Aug 14, 2017Guru - Experienced User
Did the upgrade take?
What do the lights look like?
The manual is here:
