Zilimidori
Aug 14, 2017Aspirant
WNR2000v4 cannot enable wireless radio
Hello I have just moved and am trying to set up my old router in a new apartment. After much gnashing of teeth, I finally got the wired connection working, but I cannot seem to enable the wirelss ...
- Aug 15, 2017
Have you tried following the article below?
https://kb.netgear.com/27207/Unable-to-see-WNR2000v4-wireless-network-nor-update-router-s-firmware
Mike6011
Buy a router that does not say NETGEAR. Problem solved. They know about these problems and do nothing about it because they already got your money. Very dissappointed in you Netgear.
- ElaineMAug 15, 2017NETGEAR Employee Retired
- ZilimidoriAug 16, 2017Aspirant
Thank you everyone. Elaine, I had not seen that article, and it FINALLY did the trick! Thank you for sending it.
- ElaineMAug 16, 2017NETGEAR Employee Retired
You're welcome. Thank you as well for confirming that the device is up and running!
