Zilimidori
Aug 14, 2017Aspirant
WNR2000v4 cannot enable wireless radio
Hello I have just moved and am trying to set up my old router in a new apartment. After much gnashing of teeth, I finally got the wired connection working, but I cannot seem to enable the wirelss ...
- Aug 15, 2017
Have you tried following the article below?
https://kb.netgear.com/27207/Unable-to-see-WNR2000v4-wireless-network-nor-update-router-s-firmware
Mike6011
Buy a router that does not say NETGEAR. Problem solved. They know about these problems and do nothing about it because they already got your money. Very dissappointed in you Netgear.
ElaineM
Aug 16, 2017NETGEAR Employee Retired
You're welcome. Thank you as well for confirming that the device is up and running!
