e37
Mar 26, 2018Follower
WNR2000v4 firmware update help
Dear Sir or Madam: How can I update the firmware for my WNR2000v4 wireless router by a Mac? Do I need to install the Netgear Genie app for Mac to update the firmware and adjust the settings for th...
- Mar 26, 2018
> Mac?
Download the firmware kit and follow the instructions in the Release
Notes?
Visit http://netgear.com/support , put in your model number, and look
for Downloads. Under Firmware and Software Downloads, find the kit(s).
Download the kit you want. Read the "Release Notes" file for
instructions.
> firmware and adjust the settings for this wireless router?
No. While you're in the neighborhood, look for Documentation. Get
the User Manual. Read. Look for "NETGEAR genie Setup":
NETGEAR genie runs on any device with a web browser. [...]
Your (unspecified) Mac has a web browser, right?
You could also look for "Upgrade Router Firmware".
> How can I check which firmware version is on my router?
It should be displayed on almost any page you'll see when you point
your web browser at the WNDR4300.
> I use to use a Windows PC by login to my router login webpage and
> update from there.
Other than possibly using a different web browser, it should be
pretty close to the same.
antinode
Mar 26, 2018Guru
> Mac?
Notes?
instructions.
> update from there.
