occupa
Jan 13, 2019Aspirant
WNR2000v4 Remote Desktop
I am using port forwarding and cannot connect outside the router.
I can connect inside the router.
What IP address do I use?
The one on the router (internet)
or the address from MyIPAddress.c...
- Jan 16, 2019
> Problem resolved TW/Specturn configured my Cable Modem as a bridge.
In other words, you had a modem+router, and now you have a modem.
> [...] to what the WAN/Internet port of your WNR2000v4 is connected.
> If there's another NAT router between your ISP and the WNR2000v4, then
> that could explain many problems.
Still true. You still haven't revealed what your "my Cable Modem"
actually is.
> Do you see any problems with this?
If it works, then it works. If you want an opinion on any details,
then you might consider providing some useful information on what you
have, what you do, and what happens when you do it.
occupa
Jan 14, 2019Aspirant
I will try the MyIPAddress again and report back.
Thanks for your help.
And I meant to say Time Warner now Spectrun and not Time Warner not Spectrum.
occupa
Jan 16, 2019Aspirant
- Nodism1125Jan 16, 2019NETGEAR Expert
Looks like similar to scenario 2 in this KB. https://kb.netgear.com/30186/What-is-Double-NAT
thats why the remote access is not working without bridging the modem.
- occupaJan 22, 2019Aspirant
Yes, Time Warner said that they configure the cable modem like this (not bridge) for security reasons.
When I logged into the cable modem, the bridge option was not available to me.
Time Warner had to configure on their end. The unit was a Ubee DDW365.
The NetGear firewall in not effected by this correct?
- Nodism1125Jan 22, 2019NETGEAR Expert
Hi Occupa,
The NetGear firewall in not effected by this correct? Yes. The WNR2000v4 router will act as your router in your network.
The router detect the public IP address in bridgemode modem.
Please read this article.
http://help.melita.com/ubee-setting-the-wireless-modem-to-bridgerouter-mode/
