occupa
Jan 13, 2019Aspirant
WNR2000v4 Remote Desktop
I am using port forwarding and cannot connect outside the router.
I can connect inside the router.
What IP address do I use?
The one on the router (internet)
or the address from MyIPAddress.c...
- Jan 16, 2019
> Problem resolved TW/Specturn configured my Cable Modem as a bridge.
In other words, you had a modem+router, and now you have a modem.
> [...] to what the WAN/Internet port of your WNR2000v4 is connected.
> If there's another NAT router between your ISP and the WNR2000v4, then
> that could explain many problems.
Still true. You still haven't revealed what your "my Cable Modem"
actually is.
> Do you see any problems with this?
If it works, then it works. If you want an opinion on any details,
then you might consider providing some useful information on what you
have, what you do, and what happens when you do it.
