kk60
Jul 24, 2016Aspirant
wnr2000v4 stopped working. I need tech help for dummies
router just stopped yesterday. tried every thing under the sun for 10 hrs. overwhelmed with info. i just want to know if ineed a new one (that i can't afford at the moment) I dont have a desk top. o...
- Jul 26, 2016The power light has been amber since we bought it. No I can't log into the router. Yes I was connected with Ethernet cord. Yes wired connection worked my operating system is windows 10. What the heckl is Syslog? Yes I reset many times. I've spent so much time trying to figure out if it actually die. Some where along the netgear website line it told me the actual words "end of life". I went and bought a new router.
Thanks to everyone who tried to help. It was much appreciated
ElaineM
Jul 25, 2016NETGEAR Employee Retired
Hi kk60
Welcome to the community!
How do you connect your laptop to the router (wired or wireless)?
What's the operating system of the laptop?
You said, you get internet when you plug into the router, is this with the use of an ethernet cable?
See this article for more information.
- kk60Jul 25, 2016Aspirant
I'm connected to the router with ethernet cord wich inturn the router is connected to the cable/internet modem.
for the 2 yrs I've had the router i've always connected wireless. I have a toshsiba satellite c55series.with windows 10 which i updated to about
6mos. ago
arrrrrggg!!!
- VE6CGXJul 25, 2016Master
First what is visual indication? All LED indicators look normal? Is your power adapter OK? Can you log into the router? Is the wlreless still
on? Checked the syslog? Reset the router? Does wired connection work?
