Wazx
Apr 04, 2023Aspirant
WNR2000v5 can't connect after factory reset.
I did a factory reset of my router since I needed to change some settings but couldn't remember my password. After the reset I could log in to the genie (routerlogin.net) just fine, but every time I t...
Wazx
Thank you for your quick response.
I don't know what kind of modem is used, I only have physical access to the router, not the modum.
As for the power cycling; I forgot to mention this, but I tried it a few times before posting, but nothing changed.
After the reset I followed the instructions in the manual to the letter, twice.
I'm using a browser interface which I can access both through my phone's wifi and my desktop's ethernet cable.
My router and ethernet cable seem fine, all lights are green, etc.
Only thing that seems off is that according to the interface, my router can't get an IP address.
michaelkenward
Apr 05, 2023Guru - Experienced User
So how does the Internet get to you?
My suggestion was to reboot the whole network. Not just the router.
That is why I asked about the modem. These are often also routers. A modem/router in front of a router can cause problems, including those you describe.
Have you tried plugging a PC into whatever delivers you the Internet? Leave out the router. If you can get in line, then your Internet probably comes from a router of some sort.
If that is the case, then you could see if your WNR2000v5 will work in access point mode.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Use the Router as a Wireless Access Point
Maybe that is how it was set up before you reset the router. That would have put it back into router mode.
For further troubleshooting we really need to know where the Internet comes from.
- WazxApr 05, 2023AspirantUnfortunately, I can't connect directly to the modem. I live in a shared living space (student housing). The way I understand it, every floor has a central modem with 20 routers connected to it, resulting in 20 private networks, one for each room. So I just get the end of a long cable to my room, which I can connect to the router. The modem itself is behind a lock, I believe. As such, the only way I can interact with the modem is by connecting the modem cable which ends in my room to my router. Thus, I can only reset all parts of the network except for the modem.
So, to be clear: I cannot reset the modem myself and I can't connect my desktop directly to it. It has to go through the router which doesn't seem to work anymore since the reset.
I tried enabling Access Point mode, and although my router seemed to briefly connect and change the IP address, it had the added effect of kicking me out of the router control and not allowing me back in.- michaelkenwardApr 05, 2023Guru - Experienced User
Wazx wrote:
Unfortunately, I can't connect directly to the modem. I live in a shared living space (student housing). The way I understand it, every floor has a central modem with 20 routers connected to it, resulting in 20 private networks, one for each room. So I just get the end of a long cable to my room, which I can connect to the router.You'll have to talk to the people who run the network for advice on how to use your own router on their network.
Have you tried plugging your PC into that long cable to your room?
I tried enabling Access Point mode, and although my router seemed to briefly connect and change the IP address, it had the added effect of kicking me out of the router control and not allowing me back in.That could be because the network changed the IP address on your WNR2000v5. That is a sign that you have connected the AP to a router.
You need to track down the new IP address of your WNR2000v5. Then feed that into the browser graphical user interface (GUI).
- WazxApr 05, 2023AspirantI can't directly connect my desktop to the cable. I only get a few centimeters of cable which enters my room near the ceiling, about 3.5m high. I need a ladder to reset the router. So connecting my pc with an ethernet cable is only possible through the router.
After setting up an access point, I used Ipconfig/all in windows CMD and tried both the Ipv4 address that I got and to connect directly through routerlogin.net, but neither one worked.
I then tried to manually change IP and preferred DNS on my desktop, which got me to the next troubleshooting errors "the default gateway is not available" and "the connection between your access point and the internet is broken". Coincidentally, the Internet LED on the router has gone from green to amber, suggesting that there somehow is a new problem with connecting to the internet.
I have contacted my ISP and they said that they are trying to figure it out from their end, but they tend to be a bit slow, so I'd prefer to be able to fix this myself, if possible.
