captgadget
Apr 08, 2023Tutor
WNR2000V5 Change ap mode
This router was given to me. It's set in ap mode but I would like to use Bridge mode to connect to the Spectrum Community network for my Sonos speaker. However; when I log into the router the setting...
- Apr 09, 2023
Always the first move when trying to repurpose a used device.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Apr 09, 2023Guru - Experienced User
If it was me? I'd probably give it back.
thats a pretty slow N300 device with minimal capabilities and is 2.4ghz only.
2.4ghz is sensitive to interference. I'm partial to recommending anything you stream on to be on 5ghz but that's just me.
But if you have to, I'd follow the guide michaelkenward recommended.
captgadget
Apr 10, 2023Tutor
It's on the way to the landfill.
- michaelkenwardApr 10, 2023Guru - Experienced User
I hope not.
In many many countries old electronic end up in the recycling bin for garbage. Manufacturers and retailers have a legal responsibility to support recycling.
Waste from Electrical and Electronic Equipment (WEEE)
Perhaps this doesn't happen in the USA.
