TomHM
Dec 05, 2017Aspirant
WNR2000v5 firmware update problem
I got an email about a firmware update and followed the instructions. I downloaded the file but have to browse to locate the file and nowhere does it tell me the file name to search for or what folde...
- Dec 06, 2017
I was following the instructions in the email and that was failing. So I took your advice and downloaded the .zip file from the NetGear website - and extracted the .img - and uploaded that to the rouiter and it worked just fine.
Thanks for your help.
Thomas
antinode
Dec 05, 2017Guru
> [...] I downloaded the file but have to browse to locate the file and
> nowhere does it tell me the file name to search for or what folder it
> downloaded to.
What, exactly, did you download? From where? And to where? Which
browser are you using? Did you look in your Downloads folder?
From what I see for a WNR2000v5, the file should be named
"WNR2000v5-V1.0.0.62.zip", from which you'll need to extract the file
"WNR2000v5-V1.0.0.62.img" therein. As the instructions at the target of
the "Release Notes" link on the Downloads page say, the ".img" file is
what you send to the router.
- TomHMDec 06, 2017Aspirant
I'm getting an error message on the download - MD5 Verify error
- antinodeDec 06, 2017Guru
"getting" from what, exactly? What, exactly, does "download" mean?
Send to the router? (My D7000 (V1.0.1.50_1.0.1) says "Upload".)
If so, then that sounds like a corrupt kit. If the ".zip" archive
were corrupt/incomplete, then you should get a complaint when its
contents are extracted. An MD5 complaint points to the ".img" file
itself, which would most likely be Netgear's fault. You might try
re-extracting the ".zip" archive contents, but I wouldn't expect much to
change.- TomHMDec 06, 2017Aspirant
Thomas
