TomHM
Dec 05, 2017Aspirant
WNR2000v5 firmware update problem
I got an email about a firmware update and followed the instructions. I downloaded the file but have to browse to locate the file and nowhere does it tell me the file name to search for or what folde...
- Dec 06, 2017
I was following the instructions in the email and that was failing. So I took your advice and downloaded the .zip file from the NetGear website - and extracted the .img - and uploaded that to the rouiter and it worked just fine.
Thanks for your help.
Thomas
antinode
Dec 06, 2017Guru
> I'm getting an error message on the download - MD5 Verify error
"getting" from what, exactly? What, exactly, does "download" mean?
Send to the router? (My D7000 (V1.0.1.50_1.0.1) says "Upload".)
If so, then that sounds like a corrupt kit. If the ".zip" archive
were corrupt/incomplete, then you should get a complaint when its
contents are extracted. An MD5 complaint points to the ".img" file
itself, which would most likely be Netgear's fault. You might try
re-extracting the ".zip" archive contents, but I wouldn't expect much to
change.
TomHM
Dec 06, 2017Aspirant
Thomas
