DVE44
Sep 22, 2015Aspirant
WNR2000v5 Firmware Version 1.0.0.34 doesn't install
WNR2000v5-V1.0.0.34.img downloaded from NetGear Support on 2015-09-22 failed to install. I am currently using v 1.0.0.28. As an aside, checking for new firmware from the GUI, reports "No new fi...
- Sep 24, 2015
Thank you for your response.
As per RonO, Genie also reported "No new firmware version available," when I checked for new firmware. I'm currently using v. 1.0.0.28. I again downloaded the zipped firmware from support using a different browser and tried to install the .img file using the same browser (Microsoft Edge, which replaced IE in Win 10). I previously used FireFox. Still it would not update.
BUT -- resetting the router did the trick. My router is now the proud owner of v 1.0.0.34! :)
Thank you for your suggestions!
DVE44
ElaineM
Sep 23, 2015NETGEAR Employee Retired
Hi DVE44,
Welcome to the community!
Did you try to use a different web browser? Also, try to re-download the firmware just to be sure that it was not corrupted.
If you can't still install, try to reset the router by using a paperclip to poke the reset button for 10 seconds.
Resetting will erase all the settings, therefore you will have to reconfigure the router.
Let us know what happens.
RonO
Sep 23, 2015Aspirant
I have the same problem with ...34. Also when I try to download it with the Genie it only offers ver ...28
- ElaineMSep 24, 2015NETGEAR Employee Retired
DVE44 Thanks for the update! Glad to hear that it's now upgraded.
RonO Will forward that to the engineering. For now, I suggest that you manually download the firmware and install it from there.
- RonOSep 24, 2015Aspirant
As DVE44 did, I manually downloaded, unzipped, and applied the ING file and it thought about it for a while and then failed with the same message DVE44 got. I am not comfortable resetting the router, but if the Genie is not able to fetch 34 soon I will have to try it. Do you have an idea of when that fix might be done?
- DVE44Sep 25, 2015Aspirant
Hi RonO,
I didn't reset my router by sticking an open paper clip in a reset hole, but just powered down the router. There's a black power button on the back of the router, below the power cable. Press it to turn off the power, wait 10-15 seconds, then press it again. Wait for the three LEDs on the front to turn green and try the install again.
I used to power down my router every day, but from a master switch which controlled power to all of my computer gizmos (a desktop, a printer, audio system, etc.) without a problem.
Good luck,
DVE44
