didimlr
May 24, 2017Aspirant
WNR2000v5 password won't work even after factory reset
I have had the WNR2000v5 for over a year and have used the Genie with no problems and have been able to sign into the router. However, now it won't accept the user "admin" and password "password", e...
- Jun 05, 2017
That's odd. I would suggest to get a new one. It seems that you have done most of the troubleshooting steps.
didimlr
Jun 04, 2017Aspirant
I have done that, many times actually. I appreciate the response though!!! But even after using the reset button, I still don't have the correct password, it says, to sign into the router.
ElaineM
Jun 05, 2017NETGEAR Employee Retired
