uma_arepalli
Dec 05, 2016Aspirant
WNR2000v5 router Wify connectivity issue with iphone SE
Hello, I am facing problem using Wifi on my iphone SE. I have contacted Apple customer care and they trouble shooted in all possible ways and said there were no issues from their end. Also they sugg...
- Dec 06, 2016
Welcome to the community, uma_arepalli
That's strange. Did you try to reset the network settings on the iPhone?
Also, for now what you can try is to change channel on the router.
Perhaps, just try to play around and check other channels since other devices are working perfectly.
ElaineM
Dec 06, 2016NETGEAR Employee Retired
uma_arepalli
Dec 07, 2016Aspirant
Hello ElaiineM,
Awesome! It worked for me. I have changed the channel from auto to 11 and tested the wify on my iphone. It does resolved the issue. Thank you so much for your help! Appreciated.
Uma Maheswar
- ElaineMDec 07, 2016NETGEAR Employee Retired
Happy to hear that it worked!
Thank you for the update too.
