Bob-NG
Oct 29, 2017Aspirant
WNR2000V5 with version 1.0.0.12 firmware
I have a WNR2000V5 router that is unable to take any firmware upgrades. It is a 1.0.0.12 The Netgear website proclaims "1.0.0.18" as the initial release, so what do I have? Is this the reason w...
- Nov 19, 2017
The replacement router arrived today. It was loaded with 1.0.0.34 firmware and happily took the update to 1.0.0.58.
My problem is solved, though I never found out how I ended up with pre-release version of the firmware
I guess it doesn't matter now.
ElaineM
Nov 08, 2017NETGEAR Employee Retired
Yes, can you try the same steps for your version?
mannynaber
Nov 11, 2017Aspirant
None of the "fixes" mentioned work, I have had the exact same issue with no way of upgrading firmware. Please help
