Bob-NG
Oct 28, 2017Aspirant
WNR2000V5 with version 1.0.0.12 firmware
I have a WNR2000V5 router that is unable to take any firmware upgrades. It is a 1.0.0.12 The Netgear website proclaims "1.0.0.18" as the initial release, so what do I have? Is this the reason w...
- Nov 18, 2017
The replacement router arrived today. It was loaded with 1.0.0.34 firmware and happily took the update to 1.0.0.58.
My problem is solved, though I never found out how I ended up with pre-release version of the firmware
I guess it doesn't matter now.
Bob-NG
Nov 14, 2017Aspirant
The router was purchased on Amazon.
Two or three days after I spoke to Netgear customer support, I received a satisfaction survey.
Naturally, I responded that I was unhappy with the experience.
I'm not if this is what prompted it, but the next day I started getting calls from Netgear. At
first I didn't recognize the number on the caller ID, so I didn't answer it, but on their 4th
attempt I did.
The agent walked me through a few things and determined that the router was defective, and
offered to send me a replacement unit. I only had to pay ~$16 shipping to return the old modem.
This is a satisfactory response. So while I may never understand how I ended up with a router
that had a pre-release version of the firmware, in a few days I will have a replacement which hopefully
will take updates.
Thanks to all for your suggestions!
Bob-NG
Nov 18, 2017Aspirant
- michaelkenwardNov 19, 2017Guru - Experienced User
I have participated in various beta trials – on one now – but I have yet to see a device that could not accept "post-beta" firmware.
They always ship with the first official release, and you can flash that on top of beta firmware.
I have seen beta hardware that needs strange tweaks to get it to play nice, but it always works in the end.
Like you say, puzzling.
- mannynaberNov 20, 2017AspirantGreat, I'm still stuck with a pre dated router that can't update firmware
