mighty_warrior
Dec 05, 2017Aspirant
WNR200v0v5 installation problem
 Hey Community,  I tried to install my new N300 WLAN Router (Model: WNR2000v5) according to the user installation guide unsucessfully. Every time I try to Log in at www.routerlogin.net it shows follow...
- Dec 10, 2017
Hey antinode and michelkenword, thank you very much for your effort and your quick answers!! I reseted the router again now and set up the configurations manually. In an other Forum I read that I have to use static IP adresses because of the "ancient" motorola modem, so I used them. and it worked!!! Yeah!!!!
Thank you for your help!
antinode
Dec 05, 2017Guru
   Welcome to what may be the worst error message in the world.  For an
explanation, try:
      https://community.netgear.com/t5/x/x/m-p/1365830
   Briefly, the idea is that "[www.]routerlogin.net" should point to
your own router, but that's true only if you use your own router for DNS
name resolution.  Irregardful, you should be able to get to the thing
using its IP address, if you can determine (or guess) that.  Perhaps:
"192.168.1.1".  You can often get it from your computer's IP
configuration as the default gateway or router address (or some similar
description).
