mighty_warrior
Dec 05, 2017Aspirant
WNR200v0v5 installation problem
Hey Community, I tried to install my new N300 WLAN Router (Model: WNR2000v5) according to the user installation guide unsucessfully. Every time I try to Log in at www.routerlogin.net it shows follow...
- Dec 10, 2017
Hey antinode and michelkenword, thank you very much for your effort and your quick answers!! I reseted the router again now and set up the configurations manually. In an other Forum I read that I have to use static IP adresses because of the "ancient" motorola modem, so I used them. and it worked!!! Yeah!!!!
Thank you for your help!
michaelkenward
Dec 06, 2017Guru - Experienced User
- mighty_warriorDec 10, 2017Aspirant
Thank you for the link! my Internet LED shows orange. And I tried to put off my modem and the router and I used the the cable from netgear, but still it kind of doesn't lead me to the routerlogin.net page. I can use already the router's wifi and visit other internet sites.The IP adress is: 192.168.113.254 , when I tipe "ipconfig" into CMD.
- michaelkenwardDec 10, 2017Guru - Experienced User
Go back to basics. Adding a new router can confuse the poor things. Reset the router and rebuild the network from the ground up.
- Turn off and unplug the modem.
- Turn off the modem router and computers.
- Plug in the modem and turn it on. Wait 2 minutes.
- Turn on the modem router and wait 2 minutes.
- Turn on the computers.
If that doesn't work, then at least you know you have done the basics and can investigate other possibilities.
- antinodeDec 10, 2017Guru
To what is the router's Internet port connected?
Visit http://www.netgear.com/support , put in your model number, and
look for Documentation. Get the User Manual. It explains what the LED
indicators mean.
> [...] I tried to put off my modem and the router and I used the the
> cable from netgear, [...]
I don't understand that. What, exactly, is "my modem"? What,
exactly, is connected to what?
> [...] it kind of doesn't lead me to the routerlogin.net page.
A clear description of what you did, and a clear description of what
happened when you did it, would be more helpful than what anything "kind
of doesn't" do.
> [...] I can use already the router's wifi and visit other internet
> sites.
Really? Then what's the problem?
Whose "The IP adress" is that? The Windows system? The gateway?
The DNS server? It would be more helpful to copy+paste the whole
"ipconfig" report here.
I would not expect to see an address like 192.168.113.254 associated
with a WNR2000v5. Are you connecting to the WNR2000v5, or are you
connecting to your "my modem"(+router?)?- mighty_warriorDec 10, 2017Aspirant
I reseted now the router, switched off the laptop, the modem and the router, waited 2 min, switched on the modem waited 2min, schwitched on the router and waited 2 min, schwitched on the laptop. Then it led me to the "www.routerlogin.com" when I opened the browser. Then I could decide between acces point modus or standard modus. I choose acces point modus. The next step was about the IP Adress and said start your browser again. I did it and tried to visit "www.routerlogin.net". Didn't work. No Internet connection anymore.
antinode wrote:Visit http://www.netgear.com/support , put in your model number, and
indicators mean.I downloaded the user manual and read the part about the LEDs.
> sites.
-> The Problem is when I switch off the Laptop it doesn't work anymore.
-> that was the IP Adress of the gateway.
connecting to your "my modem"(+router?)?-> I have connected my Router WNR2000v5 to a Motorola Cable Modem
