mighty_warrior
Dec 05, 2017Aspirant
WNR200v0v5 installation problem
 Hey Community,  I tried to install my new N300 WLAN Router (Model: WNR2000v5) according to the user installation guide unsucessfully. Every time I try to Log in at www.routerlogin.net it shows follow...
- Dec 10, 2017
Hey antinode and michelkenword, thank you very much for your effort and your quick answers!! I reseted the router again now and set up the configurations manually. In an other Forum I read that I have to use static IP adresses because of the "ancient" motorola modem, so I used them. and it worked!!! Yeah!!!!
Thank you for your help!
mighty_warrior
Dec 10, 2017Aspirant
Thank you for the link! my Internet LED shows orange. And I tried to put off my modem and the router and I used the the cable from netgear, but still it kind of doesn't lead me to the routerlogin.net page. I can use already the router's wifi and visit other internet sites.The IP adress is: 192.168.113.254 , when I tipe "ipconfig" into CMD.
michaelkenward
Dec 10, 2017Guru - Experienced User
Go back to basics. Adding a new router can confuse the poor things. Reset the router and rebuild the network from the ground up.
- Turn off and unplug the modem.
 - Turn off the modem router and computers.
 - Plug in the modem and turn it on. Wait 2 minutes.
 - Turn on the modem router and wait 2 minutes.
 - Turn on the computers.
If that doesn't work, then at least you know you have done the basics and can investigate other possibilities.
