mpuppet's avatar
mpuppet
WNR2020 - 403 forbidden error on Port Forwarding
When I initially setup this router, I had added one custom port forward service that works. However, now when I try to edit the existing setting I get a 403 forbidden page that opens in the main fram...
  • Ontarioeast's avatar
    Ontarioeast
    May 13, 2018
    Same problem here this month.  But I had successfully set up multiple rules last year.  I finally resorted to installing older versions of the firmware and found this problem begins with 1.1.0.44.  So I set up the router as desired by installing 1.1.0.40, defining the required port forwarding rules, then installing the latest 1.1.0.50 - the settings were retained.
