mpuppet
May 12, 2018Aspirant
WNR2020 - 403 forbidden error on Port Forwarding
When I initially setup this router, I had added one custom port forward service that works. However, now when I try to edit the existing setting I get a 403 forbidden page that opens in the main fram...
- May 13, 2018
Same problem here this month. But I had successfully set up multiple rules last year. I finally resorted to installing older versions of the firmware and found this problem begins with 1.1.0.44. So I set up the router as desired by installing 1.1.0.40, defining the required port forwarding rules, then installing the latest 1.1.0.50 - the settings were retained.
mpuppet
UPDATE: Performed a factory reset. Added one port forwarding service. Tried to add a second one, 403 forbidden error. Same error if I try to edit or delete the existing service. Is this a known issue?
mpuppet
UPDATE#2: I found a newer firmware, V1.1.0.50_1.0.1, tried to add a port forward service, got the 403. Did a factory reset, added one port forward successfully, but got the 403 when attempting to add a 2nd. The difference now is that I can successfully delete or edit the existing service, and I can successfully add one back in, but only one.
- OntarioeastMay 13, 2018Aspirant
- mpuppetMay 21, 2018Aspirant
Good idea, thanks. I will try that later and report back here.
Well, that sorta worked. I was able to create a 2nd custom port forwarding service, however, I wanted to use the same internal port 80 and received the error: "The specified port(s) are being used by other configurations. Please check your configurations of Remote Management, Port forwarding, Port Triggering, UPnP Port Mapping table, RIP, and Internet connection type"
I know this is not true, but I tried entering it again with internal port 81 and it worked. I then entered a 3rd port forward service on a 3rd IP with internal port 80 and it worked. Proof that I should be able to have multiple port forwards to different IPs all using the same internal port numbers. However, when I go back to that 2nd entry and try to change the internal port back to 80, I get that same error message. This IP is not configured anywhere else in my settings except for the Address Reservation. To me, this seems like a database bug, as if 2 entries with the same value cannot be next to each other on the same table. I have an older model Netgear router that does not have this problem. I want to try going back to factory settings on the older firmware though, and build up the setting from scratch again because by jumping back, I noticed that the IP of the 1st port forwarding service I had entered changed from 192.168.1.88 to 192.168.1.881, without my input, an impossible address, lol. Gotta get away from these bugs!
- antinodeMay 21, 2018Guru
> [...] I was able to create a 2nd custom port forwarding service,
> however, [...]
> I know this is not true, [...]
You're ahead of me. With my weak psychic powers, I can't see any of
your port-forwarding rules (successful or proposed). Do you have UPnP
and remote management disabled?
> [...] I want to try going back to factory settings on the older
> firmware though, [...]
Probably wise (or at least worth a try), but without seeing the
details of your rules (which include more than one port number), it's
tough to tell whether to expect much improvement.
- mpuppetMay 24, 2018Aspirant
I did a factory reset on the 1.1.0.40 firmware and started building by settings back up. This time I had no errors with the port forwarding rules all pointing to the same 80 internal port and I was able update the firmware to 1.1.0.50 and keep my settings.
I'm calling this a workaround, not a fix. Looking forward to the next firmware update.
I may end up replacing this router anyway for one that has better performance.
Thanks to Ontarioeast for the workaround suggesstion.
