mdonovan87
May 31, 2016Aspirant
WNR2020- Setting up webpage that comes up when guests access guest network
Anyone know how to set up the webpage that comes up when guests access the guest network? I'm using the WNR2020 router. Thanks so much.
It can be done using a different hardware.
Mostly you'll be able to find this feature in our Business Products and it's called HTTP Redirect.
You may want to check out some Access Points such as WAC720, WAC730.
- ElaineMNETGEAR Employee Retired
Hello mdonovan87
Welcome to the community!
Perhaps you're looking for something like URL redirection?
This feature is not available on the router model that you have.
- mdonovan87AspirantAh, okay. Thank you so much for the information. Can this URL redirection be done another way like through a program or something or is a different router required?
