meik520
Nov 18, 2015Aspirant
WNR2200 - Vulnerability ID: NON-2015-0211
I got the warning Non-2015-0211 from my Avast scanner. Searching for that I found this message: WARNING Vulnerability ID: NON-2015-0211 on my Netgear Router WNR2200 with Firmware V1.0.2.24 Mainte...
- Jan 08, 2016
Per our engineers, there will be no firmware updates on EOL products.
For all other products, our team is still investigating this matter.
Also, kindly make sure that you have followed the suggested solution by Avast.
Check for Alert messages stated on your Avast software. You may see this by clicking on the "Details" link.
After selecting it, scroll down and look for the "Alert messages."
meik520
Nov 26, 2015Aspirant
I am waiting for updates current firmware V1.0.2.24
Best regards, Eugene.
ElaineM
Nov 30, 2015NETGEAR Employee Retired
Hi meik520
Do you have the same window as below?
Even if shows that vulnerability report under Network Threat it shows no problem.
Can you confirm?
- meik520Nov 30, 2015Aspirant
Hi, all!
I see this screen:
- ElaineMDec 01, 2015NETGEAR Employee Retired
Thank you for the screenshot.
What's the version of your Avast?- deputydawg1Dec 01, 2015Aspirant
I got the same screen shot and I have the Avast premier
