meik520
Nov 18, 2015Aspirant
WNR2200 - Vulnerability ID: NON-2015-0211
I got the warning Non-2015-0211 from my Avast scanner. Searching for that I found this message: WARNING Vulnerability ID: NON-2015-0211 on my Netgear Router WNR2200 with Firmware V1.0.2.24 Mainte...
- Jan 08, 2016
Per our engineers, there will be no firmware updates on EOL products.
For all other products, our team is still investigating this matter.
Also, kindly make sure that you have followed the suggested solution by Avast.
Check for Alert messages stated on your Avast software. You may see this by clicking on the "Details" link.
After selecting it, scroll down and look for the "Alert messages."
walter1337
Dec 06, 2015Initiate
i have the same problem with my Netgear router. I hope there will be a update son.
alvinshookduff
yes i have thesame vulnerability.
- ElaineMDec 07, 2015NETGEAR Employee Retired
Hello,
Our engineers are investigating on this reported issue.
Kindly make sure your devices are registered.
Once done, install teamviewer and let me know your contact details together with the preferred date and time when should we reach you to troubleshoot further on this.
Thank you!
- rw4Dec 08, 2015Aspirant
I keep getting the same warning, how ever, I have a WNR1000v2-VC. Please is there any way to fix this? Thank you
- ElaineMDec 08, 2015NETGEAR Employee Retired
Hi rw4,
I will forward that info to our engineers.
Do you happen to know the version of your Avast software?
What's the operating system of the computer?
Also, kindly install Teamviewer and let me know when can we reach you to troubleshoot on this.
Thank you!
